compyelc4
- Joined
- May 1, 2002
- Messages
- 609
- Location
- Dayton, Ohio
- Corvette
- '95 LT1 Coupe, Comp Yell; C6 Roadster, Vel Yell
Can anyone tell me if the water temperature sensor harness (on front of LT1-'95) needs to be plugged into water pump in order for Opti to work.
I'm in process of replacing water pump, so I thought I would clean the opti up a bit. The opti was running fine when I pulled her off but now she will not fire at all. Just as I expected, the spark distribution pins and the rotor (at 5,000 miles!) were crudded up real good due to the fact that my fresh air line was bent at a right angle preventing opti from venting fresh air. That coupled with the fact that my waterpump leaked a small amount before I caught the problem. I cleaned the pins and rotor up real well with emory paper. I did not even go into the optical portion of the opti. Then I reattached the opti and all belts, tubes, wires and harnesses but I left the water pump off (and the water temperature harness that goes into the front of it). The opti will not fire at all. Do I need that temp sensor harness plugged into the waterpump in order for the opti to work?
I'm at a loss. I need help.
