Bonnell
Last year about this time, I had my '88 tuned up by a dealership in Little Rock. I was surprised that it did not run much better than it did when I took it in.
It had a rough idle and seemed to miss some during acceleration. Over the past year this has gotten worse. Recently I was concerned because I heard a loud groan or creaking noise from the area of my rear driver's side wheel. I posted it here and several people thought that it might be a u-joint and one thought that my ebrake might have stuck.
I have recently found a mechanic that is well known in the area for working on Corvettes. The noise doesn't occur anymore but I thought that this would be a good time to check the guy out by letting him check the car out.
What a great experience. I had a tune up, transmission service, oil change, tire rotation, fuel filter change, a list made of items to be corrected or serviced over the summer (simple things that would need parts ordered like something called a speed sensor and the steering rack boot), and he even changed a backup light that I had not noticed was out. He completely checked out the car and took a great deal of time explaining to me everything about things that I asked. The u-joints were fine - it may have been a ebrake issue. It cost me $442.59. What a great place.
The tune up that I got from the Chevy dealer last year cost me $350 and they didn't even change the fuel filter. What we did find was this:
NONE of the spark plus were seated - NONE. The one on the passenger side rear was cross-threaded. The vette mechanic had to take panels off of my car to get to it, get it out, and re-thread the place where the plug goes in. The plug wires were changed on the distributor cap in such a way as to bend the metal posts that the wire plugs into. The screws that screw down into the cap were tighened too much so that the screw tip was inside the cap. You could see where there was arcing from on of the contacts over to the screw tip.
Now, this occurred after they broke my hood release - I know, the cables break on their own sometimes but the mechanic pulled so hard he broke the plastic cover that surrounds the hood release. I had to bring it home (they couldn't get it open). I ordered a tool that was recommended by a member here. I got it open then they said they would fix the cable. They did the 'tuneup' that I have described above and didn't fix the hood release.
It is hard to belive that a large Chevy dealer could have someone that inept working there.
Anyone else out there ever have this kind of experience?
ad Yes the dealer would take your money with a smile some of the Techs can only diagnos if the computer or the engine light is on had that problem with my ecm one said module corvette specialist diagnosis was accurate and correct .......We just have to be careful just like a good doctor
