- Admin
- #1
Someone brought this to my attention and it should probably be mentioned here. The following information comes from the ZR-1 Net and has been edited/corrected by me:
In some of the original LT5 engines it has been found that some of the secondary port vacuum actuators are installed upside down causing the actuators not to open completely. The fix is to just turn them rightside up.
According to Gordon Killebrew: "If the actuator lever, that extends from the center opening of the actuator and is attached to the bladder within the actuator, is sitting at an angle, it is 180 degrees out of correct position (on backwards). The actuator lever end that is attached to the actuator diaphragm should be pointed to the center of the engine. When installed correctly the lever is in a straight line with the port throttle arm."
In order to determine if they are opening correctly: connect a vacuum gauge to the secondary port vacuum hose system as described in this thread in order to measure how much vacuum is needed to open them. Check your Corvette Service Manual for correct specs.
http://corvetteactioncenter.com/forums/showthread.php?s=&threadid=14272
The second problem is that the new actuators from GM (the diaphragm piece is red) are not built correctly. The spring is not centered on the post in the back of the can. The actuators either have the spring on the post or off to the side. The actuator valves equipped with the springs that are off to the side bind as the arm is pulled in. They are either good (spring on the post) or bad (spring off to the side). There's no in-between.
NOTE: The arm must retract into the can all of the way to the taper on the arm for full opening of the secondaries.
