Re: Re: ...I need to clarify
BullWinkle said:
The reason why I brought up the potential complexity of the LT5 is because I'm reading a lot of threads where guys are looking for "certified ZR1 technicians." My interpretation of that is that the LT5 is complicated and repairs on it shouldn't be done by the home mechanic.
But 405 HP back in 1993? That is an insane number considering the LT1 back then was putting out 300 right???
Yes and no. Depending upon what kind of work needs to be done to the engine, special J-tools are required. Most regular maintenance can be done with no special tools or training needed. In the almost 8 years that I've owned mine I have:
Changed the spark plugs and ignition wires, battery, oil and filter, air filter, plenum gaskets, throttle body gaskets, secondary port vacuum pump, secondary port vacuum line system, secondary port vacuum solenoid, secondary port vacuum actuators, (pulled the starter out and cleaned it and the contacts), oil pressure sensor, alternator, serpentine belt, crankcase ventilation hoses, crankcase ventilation cover gasket, MAP sensor and related vacuum hose, PCV valves and related hoses......i'm sure I'm forgetting something.
However, you get the point. NO, not all of those parts needed to be replaced....a few of them did, and most of the stuff that was under the plenum was replaced simply because it's a pain in the butt to pull the plenum off and since I was under there, I figured, what the hell.
I'm not a mechanic....about 90% of what I know, I have taught myself through the use of the 1990 Corvette Service Manual.
Why do I prefer to seek out a ZR-1 Certified mechanic if I do take my Vette to a dealer - I do so in the hope that this mechanic is experienced enough in working on all Corvettes and has an understanding of what a Corvette owner is....as well as an appreciation for the model and won't treat it like it's just another Cavalier or Beretta coming into the shop. The LT5 motor is a much different design than a pushrod motor and the software that runs the car is much different than that of a pushrod motor so hopefully, the ZR-1 certified mechanic will have a better chance at possibly diagnosing and repairing the problem rather than throwing parts at it hoping to get lucky.
I have heard of too many horror stories happening to ZR-1s at the dealership level. I'm not saying that you should not take your ZR-1 to a dealer. What I am saying is to be careful and do your research first.
The LT5 motor is extremely reliable and is more complex than the standard pushrod motor, but it's not impossible to maintain and fix.
