- Thread starter
- #21
7
78SilvAnniv
I'll take a stab!
I think the radiator cap is rated for a particular psi to hold the pressure of the cooling system. If the cap is old and compromised, perhaps it is able to suck air? Or fluid is allowed to blow out?
I have heard of instances where a cap with too low or too high psi adversely affected the cooling system.
Heidi
Heidi
) and my mistake for calling it a expansion tank. It is a recovery tank. So first I will try the rag trick that RodsnRides mentioned, will this work OK with the hood open:confused , it seam to defeat the purpose? Now will the recovery tank suck back the overflow once it cools down. Also did I make a big boo boo by not filling the recovery tankin the first place? The tank never had a mixture in it since I did the swap and I am worried that air was sucked back in and caused more overheating concerns.
