- Thread starter
- #21
- Joined
- Feb 8, 2004
- Messages
- 1,102
- Location
- Southeast, PA
- Corvette
- 2003 50th Annversary Red coupe, beautiful !
Changing coolant & sign of the times. . .
For those following my mechanical/coolant escapades, I drained the "Global" whatever coolant and installed Preston Green ethylene Glycol and I wanted to just check the freezing point, and my 15 year old anti-freeze tester was shot, so I set out to find an 'Anti-freeze' tester. Easy you'd took ? ? ? Guess again. I hit four auto parts stores before I found a prestone tester at Auto Zone. Cost $2.95 and my freshly serviced cooling system is good to -34 degrees. There isn't any testers for Dex Cool I assume as I couldn't find a single one.
Well....I'm not sure what "Global" antifreeze is and we still haven't established if what you put in the engine was actually propylene glycol or ethylene glycol but...if the bottom line question is: What's safe for a cast iron engine, that easy.
If the coolant mix is safe for an aluminum engine it will also be safe for a cast iron engine, so be it propylene or ethylene, it will be fine as a 50/50 mix in a cast iron motor.
