lhdg865
Can anyone help me decode the casting numbers on my 68 Coupe differential? The numbers cast on it are as follows: 2 AT 71 W. Thanks for any help.
AT is the code for 3.08:1 posi for big blocks; W indicates the Warren, Michigan plant. I believe the 2 is for the second shift and 71 is the year.
I believe the '71' would be the 71st day of the year the diff was assembled. What's the casting date of the case itself?
The casting # is on the lower LH side of the diff. A letter and 2-3 numbers- A 238 = Jan 23 1968 or 1978.
If you have a 71 chances are someone blew up the original 68 posi case. The 63-64 & 65-69 cases were not the best. The 3's 4's were junk, the 5-9" not much better. The '71-9 cases were better, had better spiders, but lousy clutches. Sounds like someone was in there, just hope they built it correctly and addressed the weak areas in there.
Thanks to everyone for the good information. I'm going to crawl under this weekend and check out the other numbers. I guess it really doesn't matter one way or the other, but I am always interested in finding out a bit more history on my car. Thanks again.
Here it is, this is a cleaned up diff I built for a guy- Now for you sharpies out there what year is this for?
Let me see if I have learned anything...How bout October 18th 1963 or 1973???
