72 differential fill plug seems to be leaking. It takes a 5/8 open end wrench on plug but no room to swing wrench ( because of spare tire bucket and half shaft). Is there a tool out there that I can put on my ratchet ( socket/ crows foot or otherwise) to remove without taking spare tire bucket off. On replacement do I put teflon on threads? I've also heard that the original rear pumpkin's crack. Could the leak be coming from a crack? Where do I look? How do I tell ? Can the seal from the rear cover pumpkin to diff go bad after 36 years? Would probably put in 336 gears if I have to do this repair. Is this O.K. for a 454 with auto trans? Sorry for all the questions. Thanks.
