G
Goodnt
The lighting behind the coolant temp/gas milage section of my digital dash has gone dark. I am assuming a new bulb is needed. Having researched the threads and information on digital dash repair, it says I need a Halogen 882 bulb. I am thinking many of you have experience with replacing a burnt bulb and have a couple questions:
> can the bulb be replaced by just removing the front cover of the digital cluster? any tips? sounds easy? (I am not a mechanical expert)
> I have looked at a couple parts vendors for the bulb-- Covette Central sells one (not halogen) and Zip sells one (halogen). Both of these guys do not identify the bulb as an 882 size, just that 4 are used behind that area of the cluster. Am thinking this is the right bulb, but can any of you lead me to the right bulb? Chevy dealer no longer stocks them.
Thanks for any advise. While the bulbs are not hugely expensive, I don't want to waste my money on the wrong thing-- would rather put the money in the tank.
