Y
yellowvette
Boy I'm stuck on this one. My '77 l-48 w/350 trans. has developed a "tapping" kind of noise from within the DISTRIBUTOR itself, I belive it could be "arcing" current, as noise doesn't seem mechanical (by listing with a metal tube), seems to be most noticeable when cold. Worst part is high end performance is not great, low end is fine, will get to red line in low gear fine, but second and third will not exceed about 4200 rpm. New cap, coil, rotor, wires, module, pick up coil (have never replaced capacitor) .Anyone with any insight here, I'm crazy with this, had it apart a dozen times.........
