Hi all
my '65 coupe has the 327/365 sb motor.
is anyone familiar with the Breakerless SE Electronic Ignition Conversion kit offered by Lectric Limited.
It seems to be pretty good. $159.00 and converts the distributor to electronic and still retains a stock appearance with the cap installed so it will even still fir under the shielding.
Also, according to my mechanic, with the electronic conversion, I don't haveto be as concerned with worn bushings causing shaft wobble as I would be if the distributor was stock with standard points and condenser as it only concerns itself with the rotation of the shaft where the stock set-up would allow the timing curve to get thrown off by any wobble in the shaft.
I know my bushing are somewhat worn and the original plan was to pull the distributor and rebuild it stock but now my mechanic thinks this method my be a little better of an idea and he said it would save about half the labor rate because he wouldn't have to pull and spend about 2 hours on the distributor alone, before even doing the timing. The conversion kits installs in about 15 minutes.
This is the same kit that is advertised in the latest NCRS Driveline (issue 157 May-June) on page 42.
I know nothing at all about this stuff so any opinions are greatly appreaciated.
Thanks!
Barry
Thanks!
Barry
