Do i have an electrical problem?
  • Thread starter Thread starter Stogie D
S
Stogie D
mornin all - I have already asked this Q to a 99 owner & did not get the answer I was hoping for so I'll put it out to all of you just to clarify - I just bought a 99 C5 - when I turn on the PARKING LIGHTS, the headlight doors open - the headlamps don't come on but the doors are open - the owners manual is not clear if this is correct but I suspect that it is not -
Are the headlight doors supposed to open when just the parking lights are turned on?
I'm thinking I have a problem with the multifunction switch but don't know that for sure -
would appreciate any info - I normally always drive with my parking lights on but having the doors open really bugs me -
Thanks much, D.
Did you have the headlights on first ?
"● If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on."
hmm shouldnt your DRL's ( parking lights : Daytime running lights ) be on anyways without having to select parking lights ?
Sorry if i am not much help, I just got my C5 saturday and we've had a blizzard ever since.
shawn - No, the headlights are not on first - the manual is clear about that aspect of it -
when the light switch is off & I turn on the parking lights only, the headlight doors open -
as far as i know, the DTR's are the front marker lights only -
D.
anybody?
anybody else got any ideas? - does your 99 do this? - - help, D.
I do not have a C5, but this functionality does not sound correct. The way shawnfate has described is how my C4 operates.
I've got a 98 and no, if you turn on the "Parking Lights" only, the headlights shouldn't swing up.
Sorry but I don't have any suggestions as to what may cause this.
Maybe one of our more knowledgeable members will step in soon with more info.
:wJane Ann
Maybe GMJunkie has an idea, Jesse you out there ?
Jesse, thanks for jumping in here. Hopefully the OP will get back with the codes.
ureka - I thinka
mornin all - after searching through many threads I found what I believe is the answer & will leave here as it was really hard to find - came across it using the keyword "multifunction switch" - & it has nothiing to do with the switch - go figure - EVIDENTLY if one of the headlight door actuators goes bad, stripped gear as usual, this sends bad electrical data, ie current or amp load data to the computer - bad info in, bad info out - so the comp tells the headlight doors to open when the switch is moved to the parking light position - & I thought the vacuume actuators were a pain in the butt - anyway, things should go back to normal when I replace the headlight motor - we'll see - D.
Hey D, you may be on the right track... I thought I remembered having something similar with my headlights in the recent past so I went through a search of my old threads and came up with this one:
http://www.corvetteactioncenter.com/forums/c5-technical-performance/120865-c5-headlight-issues.html
I hope it helps with your troubleshooting. Keep us in the loop and post your findings. The newest C5s are almost 7 years old now and more issues are going to present themselves soon.
Maybe we should start a list. :L
:wJane Ann
May sound silly but I'd just take a road trip over to Old Fort NC and see Junkie .Hell It's only 1200 miles for me when I have a problem .:)My wife calls my cell phone after a couple days wanting to know where I am .I just say" I told ya I was going to get the car serviced and I'll be home in a few days. ";shrug
#4000
Now Vetteboy, that's funny!
Thanks all for the info - I put a headlight door motor in and all is well - the doors coming up at the wrong time has stopped - had nothing to do with the switch, it's just the way stuff talks to the computer - and now for the next fun thing to do - one of the rear exhaust flanges broke clean away from the pipe today - seems to be a common problem from what I read - GM supposedly put out a TSB about it but i haven't seen it yet - looks like it's gonna be a bugger to fix - I dont see how it can be welded in place although I think you would have to tack the flange before removal to get proper alignment - I'll have to dig around in here on this one - I love these cars - really
