Luiparra
- Joined
- Jan 11, 2014
- Messages
- 40
- Location
- Melbourne, FL
- Corvette
- 2008 Coupe, Crystal Red metallic - 6 Spd P/shift
My 2008 coupe has annoying rattles when car is moving at any speed and turning, going through bumps, etc. I removed the top and noticed that the pins were loose, so I tightened them, dressed them up with a little grease and the rattles went away. However, they came back after a couple of months. Removed the top again, found the pins were nice and tight and redressed the pins with grease (they still had grease from previous application) but this time the rattle has not gone away. Sometimes I think I am driving my old '68 which was a rattle box ! I can't believe that with all the technology, these modern Vettes still RATTLE !
Any suggestions? or do I have a failed weld somewhere in the cabin cage or windshield frame? The noise is annoying and drives me insane. Need help!
ad
ad
You have done what is normally suggested as a fix. I have heard about a trick of wrapping the pins with plumber's silicone tape. That would be easy to try.
