Vettehead Mikey
fine69 said:Hi All,
I've been having problems getting my headlights to function. The lights turn on, and you can hear them trying to actuate... but they do not lift up.
I had installed the Edelbrock Perrformer setup, including a .510 lift cam, so the engine has quite a lope to it.
My question is --- with this high lift, is the vacuum therefore adversely affected, i.e., weaker? If so, does this sound like a likely reason the lights wont actuate? They worked fine before my rebuild. :confused
Thanks.
If you've got enough vacuum to operate the engine, you've got enough to raise and lower the headlights.
There's most likely a major leak somewhere in the system and it comes down to long hard hours of troubleshooting to find it. Good luck.
