G
GeorgeT
I just replaced the LH Door Adjar Switch. Worked great when "exercised" by hand - lights go on and off normally after a 15 sec. delay. When I shut the door, the switch broke apart leaving only the mounting section on the door; everything else went into the door. I was able to fish out everything but the guts to the switch which fell into the door.
My question, the replacement switch had an extended tip where the original's tip was flush with the top of the button. I got another from the local dealer and he says they are all the same. Did I do something wrong?
