R
redmist
The door hinge bushings on my drivers door were wasted causing a significant sag. Got a great kit from Zip.
Got the bottom pin out no problem but had to cut the top one in half in order to get it past the door skin.
I reinstalled the top one by inserting it from the bottom. There are little ridges at the top of the pin which lock it into the bushing so I don't think it will fall out. The door works great now and is aligned perfectly with the body. All the gaps are equal :0
Has anyone else done this repair without removing the hinges?
Any problem with the pin falling out?
