door hinge pins
R
redmist
The door hinge bushings on my drivers door were wasted causing a significant sag. Got a great kit from Zip.
Got the bottom pin out no problem but had to cut the top one in half in order to get it past the door skin.
I reinstalled the top one by inserting it from the bottom. There are little ridges at the top of the pin which lock it into the bushing so I don't think it will fall out. The door works great now and is aligned perfectly with the body. All the gaps are equal :0
Has anyone else done this repair without removing the hinges?
Any problem with the pin falling out?
Related unrelated topic.
I was able to get my pins back in the normal way. However, I had the door off and the hinge bolted to the A pillar. (Is that considered cheating?)
Will they fall out? I hope not. There is only one way to find out now:bash
I came up with an idea. Now that my doors are on, gaps filled and sanded, and all shims in place, I don't want to mess any of the alignment up. My doors have to come back off to paint in the jambs. I decided to drill and install a couple of zip screws in the door to door hinge before unbolting it.
This way, when I put it back on I will rough align and bolt the main bolts, then when I put the zip screws back in the doors will be in the exact some position:J
I think this will work better than scribing lines around the hinge or putting tape around it.
