- Moderator
- #1
- Joined
- Nov 9, 2000
- Messages
- 7,488
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
Well yesterday I was finally spurred into action and replaced the door hinge spring on the driver's side. My car had a piece of steel in the tire and I sent it to work with my wife to be repaired. I had some errands to run so I was forced to put the new sticker on the plates and drive the L81. :JLast fall I put in a new horn/burglar alarm relay and that fixed that problem maybe a little too well. I had gotten used to the thing not working. As you know, if you open the door and hit the lock button and then let it come closed a little before you push it open again the alarm goes off. Then you have to stick the key in the outside lock to turn it off. I was downtown when I did this and, of course, everyone looked at me like I was an idiot (more so than usual).
I decided it was time to replace the door spring that was laying on the bench all winter. I bought one of those bent screwdriver installation tools from Echlers too but just wasn't too sure about prying around things painted.
I thought I'd take a look at it and see what I needed to do then work out a way to protect the surrounding area before I started serious leveraging. First I read the instruction sheet. :eek That is against all that is holy but I did it anyway. Then I slipped out the old spring piece and slipped in the new spring making sure it went into the slots. Next I put the bent screwdriver through it and pried lightly while closing the door just a tad. The spring slipped over the roller and was installed. Way too simple. Why didn't I do it 3 years ago?
All I have to do now is wipe it down with some Prep-Sol and paint it with some brush on touch up paint that I also got from Ecklers. The original spring is painted so this one needs to be also.
I never got to the place where I needed to protect the surrounding area but without that bent screwdriver tool it would not have been so easy.
Tom
Tom
