Door Jamb Switch, How to Connect Wires?
fine69
Maryland / D.C.
'69 Convertible Vette; '72 Z28 Camaro Rally Sport
The replacement door jamb courtsy lamp/warning switch arrived today.
Looking at the switch, there are three holes at the bottom of the post. I believe this is where the wires are supposed to connect. I just cant figure out how they're supposed to connect.
:confused
Do I just push them through, or do I need a special connector? It doesn't seem that the wires would stay in place by just pushing them through the holes.
Thank you.
Ralph
duke94
Ann Arbor, MI
71' convert and 78' both Red
You should have received some brass terminals with the switch. They push into the slots of the switch and get the wire crimped on the other end.
fine69
Maryland / D.C.
Thanks. That makes sense. Nope, the package did not include the brass terminals. I wonder if these can be found at a hardware or Radio Shack. This is exhausting.
Mooser
Ontario
1972 BB Coupe
door switch
I had to get mine through ec*lers. looked around and couldn't find anything even close enough to work. Even tried flattening out some small copper wire and using it but it would work, then not, then work, etc. The real ones installed and worked perfect.
Spent more time trying to cut corners than I saved.
Wayne robson
australia
sold my last corvette.
may also help
hi fine 69,there is a reliable source , for these in the buick riviera club , and i think they are the same. but only have phone number, it is Paul Meltzer 100 cottage street Norwood MA 02062, 781 769 7678 regards wayne.
fine69
Maryland / D.C.
Wayne,
I purchased replacement for the door jambs, door ajar, and hood ajar switches.
Is this Buick Riviera Club a source for the replacement switch or the brass terminals?
Thank you.
Ralph
Wayne robson
australia
Hi Ralph
Wayne,
Thank you.
Ralph
No im not sure if the switches are the same, but i think the small copper switch contacts are the same, Paul supplys the riviera club members with these, i have a 1965 GS, and i did mine 5 years ago and the vette is in storage and have not looked at the vettes switches, i think they where approx $15.00 a door, regards. wayne.
KOPBET
Tulsey Town
'73 Silver LS4 4 speed
Is this what you are looking for?
Door ajar switch terminals
What happened to the original terminal contacts that were on the wires? They just pull out of the switch, you can reuse them with the new switch of you didn't cut them off the wire. Thery're held in by a little tang on the side of the contact.
fine69
Maryland / D.C.
Thanks KOPBET. Those are exactly what 'm looking for!
fine69
Maryland / D.C.
Well, I tried to salvage the existing terminals. They're pretty worn and keep slipping out of the holes.
I'll go ahead and order new ones.
How far into the holes should the terminals be inserted?
Thanks for any info!
KOPBET
Tulsey Town
There should be a tang that will protrude from the side of the terminal. Sometimes that tang will get pushed back into and even with the side of the terminal. You can carefully slide a thin sharp item like a single edge razor blade into the front of the tang and pry it back up. When the terminal is pushed back into the switch the tang will catch on the inside and hold it in place.
fine69
Maryland / D.C.
KOPBET,
So the terminal should be inserted far enough to actually go all the way through the holes?
Thanks again.
Ralph
KOPBET
Tulsey Town
KOPBET,
Thanks again.
Ralph
Push it all the way in until the tang engages to hold the terminal in. Yes, it will protrude just a little bit, just enough to contact the circular disc on the end of the spring.
duke94
Ann Arbor, MI
Here's a picture of the switch and terminal. As others have said, push the terminal into the slot until the barb latches to the inside of the white plastic insulator. The terminal will stick out the other end slightly to make contact with the movable part. Pretty straight forward.
K
Kid Vette
Thanks for the info. This is a project I will be doing shortly. :beer
fine69
Maryland / D.C.
Thanks KOPBET and duke94. My terminal sare pretty shot. I'll install the wires with new terminals as you guys described.
