coptertom
Back Again, this time with door lock questions:
I just replaced the electrical pigtail for the power door lock on the driver side door. Matched up the wires (color coded), still does not work. I will get back to that.......
When I use the key to lock / unlock the door the key turns but sometimes it will not turn enough to lock. It looks like the linkage that is attached to the lock pawl is slipping or just not being able to get enough movement to the rod.
Is there supposed to be a clip that attached the rod to the pawl?
I am thinking about attempting (and I do mean attempt), to remove the door latch mechanism, to clean it up and re-grease it. IS THIS AN EASY THING TO DO OR SHOULD I JUST GIVE IT UP, RIGHT NOW? I am thinking that if I clean and re-grease it, the lock will work and not bind up, as it seems to be doing.
The assembly manual really does not have a clear picture of which rods go where and which clips to use. Would anyone have a clear picture, that I could work with or possibly a diagram of what goes where. It does not look like anyone has ever removed the door panels to work inside on the locks or window. This was apparent, when I found the metal coil that attach's to the window: laying at the bottom of the door. I am surprise the window is still working.........................
OK, guess I will stop here and hope to get the door locks fixed before asking for more help with other on-going issues.
Thanks,
Thanks,
