L
Larry G
Can anyone tell me if you have to remove the door glass to get the mirrors off of a 1978? If so how difficult is it to remove the glass?
getting the glass out of the mirror is simple.. just immerse the entire thing in laquer thinner overnite with the glass facing down... when you pick it up in the morning , the mirror will be laying there in the thinnner. do not use a plastic or vinyl bucket as the laquer thinner could melt it and leave you with a heck of a mess.
You might be able to leave the door glasses in. Lower the two bottom stops on each door glass and see if the window won't go down far enough to get to the nuts on the base of the mirrors. Assembly Instruction Manual (AIM) shows the stops and window hardware, and the mirror mounting.
