ddahlgren
I am almost done gathering parts to rebuild the drivers door to start as the guide pin is loose and the outer window seal shot along with a little window rattle. Since everything has to come out to get to the guide pin Ithought might as well change all the wearing parts inside so i don't have to open it back up again.. So far have..
Outter window seal
Inner windor seal
window guide
window rattle pads
hinge pins and bushings
new screws
new screw inserts
dielectric grease for electrical connectors
What lubricants for motor linkage etc??
What am I missing?? are there any bushings for the window mechanism that raises and lowers the window? Evene if no longer available no problem as I do have a very complete machine shop and can make anything that I can draw.. This will probably be around the time of christmas.
Dave
Outter window seal
Inner windor seal
window guide
window rattle pads
new screws
new screw inserts
Dave
