Help! dosnt crank.
  • Thread starter Thread starter captbane
C
captbane
Cant seem to win this year,just got the 89 back from a full tune ,went out to start her the other day and the key rotates to acc and no further,nothing, nada.the dash lights up,the shifter can be moved but no starter,grrrr,any thoughts?The car sat idle all winter,bad ignition switch?
Clean your key pellet and the contacts just inside of the Column Lock cylinder,Your VATS is not getting a good connection!!:upthumbs
Junkie,wow! your a tar heel transplant like me! bread and born in Fayettville,looks like ya have a vette collection two die for!Whats next on your shopping list?Something custom from the west coast?Cleaned the keys as you said,still only rotates a 1/4 inch or so past acc.Think I have a vat system problem? The spark plug wire was shorted out to the frame and I had to replace the ignition mod.to get her running,could this have screwed the vat also? I did drive it after the tuneup,seemed fine. Im an industrial maint. elct./mech up here so I thought I might redo all the batt. cons. etc I have no idea how to clean the switch contact points as you sujested.Thank you for taking the time to give me some hope on this,the summer is slipping away and Im still vetteless,grrrrr,tx agian,Doug.aka,captbane.
Actually I'm a Missouri Jack A$$,By way of Florida!!:boogie:boogieMy Collection??I buy Them,I Trade Them, I Sell Them and I work on Them!! :thumb:thumb:thumb www.gmjunkie.com
I think you have a bad Ignition Lock Cylinder or bad Ignition Switch in the column!!:upthumbs
fixed it
replaced the ignition switch, not that hard a job.
