he_mech_usmch
I am new to this forum, so hello! I have an 85 Coupe with the 4+3 DNE trans. My problem is that it seems like the trans is stuck in gear. I have verified that the linkage is not binding and the shifter is aligned for neutral. I pulled the side cover off of the t10 portion of the trans and it looks like it's in neutral since I can see the syncros on either side of the gear clutch. I can put it in 3-4 with little effort, but 1-2 is a pita. The PO stated that he was trying to "sport shift" the car prior to me getting it and got it stuck in 2nd, I am about to lose my mind after going back and forth with everything. I can't see where anything is broken, there's no metal chunks anywhere. The shift forks don't look bent, but I'm at a loss. I don't see what else I can do in the car...it's about ready to either come out and go to the trans shop or just go...Appreciate any insight.
Thanks,
Josh
Thanks,
Josh
