link
i found this thread over at LS1.com
to say the least i need some traction. ive got a 99 vette running 539 rwhp and i run at the track on street tires. ive tried drag radials but those are a joke. ive never used the NOS so basically im putting 415 rwhp down at the track (ive got 125 shot N20). people have told me to "Shave the calipers?" adn some said that it was the "spindles?" what exactly do i need to do thanks
99 SS M6 # 0047 1 of only 54 hartops Borla, Direct flo-lid, Red Maf Ends, !CAGS, Hurst Billet Shifter,Red SS engraved Shift knob, ZO6 FRC's,Red Convolted tubing, Clear Corner lenses, Firebat decals front and Back, SLP Y-Pipe, SS floor mats,custom "Anti-Rice Missle" rear sticker Centerforce Dual-Friction Clutch, Lous Short Stick, Brembo Slotted and Crossdrilled rotors, Red calipers with Reflective "CAMARO" badging
315rwhp
321rwtq
103 degress when dynoed
IP: Logged
NitrousNate
posted November 15, 2001 09:00 PM
Hey man, here's what I did. I went to the junkyard and got 2 late model camaro wheels for $50.00. I have seen the wheels on some v6 camaros but don't know what they come on. They are 16x8 on 26-11.5-16 ET Streets. They are a pain to get the bead to seat but they eventually go. I put 1/8in. wheelspacer on and bolted them up. Left the car on rear jackstands and put the car in gear and let it scrub for 2 or 3 seconds. Took them back off to see where it rubbed. It hit the upper balljoint top on the upper a-frame. It is black and tapers off. Take a grinder to the top of the ball joint(you will end up taking off about 1/4 in.) Grind off a little then put it back on and see if it hits. This will make sure you don't take off more than you have to. After you do one side the other is a breeze b/c you know about how much to take off. Remember to use the wheel spacers, they make a big difference in the clearence and fit. Hope this helps, it worked for me and have had no problems with it. If I can help you any other way let me know. talk to ya later.
IP: Logged
Red98C5
posted December 09, 2001 01:23 PM
I have done the same thing, except that I do not use a spacer. The upper ball joint and a small amount of the knuckle must also be trimmed. I now have a contact that has a jig made to take these rims as well as the 84-87 Vette rims and mill the inner portion of the rim for additional clearance so you don' t have to grind near as much.
1998 C5 coupe, ProTorque 2900, 3.42 gears, Flowmasters, BFG 275 Drag Radials, CARTEK heads-cam-programming, K&N cone air filter, 160 deg thermostat, RK Sport long tube headers.....11.74 @ 117 mph "No bottle, all throttle"
Hope this helps
Daren
