Ron Miller
- Joined
- Aug 23, 2003
- Messages
- 494
- Location
- Southeast Missouri
- Corvette
- '66 Auto Mosport Conv, '65 Nass Blue 4-sp Air Cpe
This isn't the best picture in the world, but you will notice that there is a pronounced slope downward in the driver's side exhaust extension when compared to the passenger's side. The passenger's side is about correct. Note also that the mufflers both are identically mounted as nearly as possible, so the difference in the two extensions must be in the bend angle from the rear of the muffler, although I haven't gotten beneath the car and measured in order to compare the two.
This is a complete exhaust system from Corvette Central, just installed, and I haven't yet contacted the folks to see if they have had previous complaints in this regard. The system is also supposed to be lifetime guaranteed (just return the old part, I assume, haven't got into that yet), was the primary reason I bought it from CC. Tlhey've always been a pretty good source in the past.
Before I contact CC, wanted to see if anyone else here had experienced similar problems. Any input? The driver's side exhaust extension is pulled upward as much as possible, still has a siginficant downward slope to it. It is much more noticeable when seeing both extensions together from a side view, but don't have a good photo of that yet.
Comments appreciated, I'm also going to post this on the "other" forum. Thanks!!
