R
rbryce
Beginning to think that the simplest thing to do is to just throw money at it !!!
rbryce,Let me ask this question. It seems like the discussion is either hoses (not likely to me that since each caliper has it's own hose, more than one hose would be failing at the exact time to cause the locking of both front brakes), the proportioning valve, the master cylinder or the booster. Since it was also brought up that this year corvette does not have a separate proportioning valve, that sort of eliminates that! One comment was that the brakes were both locked up and the brake pedal could not be released. What is the one thing that will cause BOTH to occur? Since the master cylinder and the booster are two separate parts, will a failure of the master cause a lockup in the booster to prevent the pedal from returning? I'm not an expert on all of these, but it seems to me that if the master has locked up, the booster, not being internally physically connected to the master cylinder, would return to it's previous state and release the pedal. Since the pedal was reported to have been locked up as well, would that point to the booster more than the master cylinder? :confused
I did pull the check valve when the brake wouldn't release and it did nothing.rbryce,
You are correct. The brake pedal connects to a push rod that controls the valves of the booster. It is not mechanically connected to the master cylinder. The pedal should return to the off position even with the master cylinder stuck fully on.
That said, a good test would be to recreate the lock-up condition and then pull the check valve out of the front of the booster. I'm betting the brakes and brake pedal will both be released.
So I guess getting this diagnosed and fixed is not a priority huh?
When I got the car, I checked all the fluids and the brake fluid was clear. The calipers were replaced a few years ago and I am almost positive they are SS lined.I agree. I wouldn't even consider trying a rebuild on this puppy. REPLACE IT. And flush your brake lines to remove any goo. I would also rebuild both front brake calipers as this could be contributing to causing the brakes to lock up as well if this stuff is preventing the pistons from moving freely. Flush the rear lines to check for any contamination in the rear circuit and deal with that also. Corvettes stock brake lines are steel, not stainless steel, and yours could be practically rusted through from the inside out. After all the troubleshooting to date, can't believe this pile of goo in the master has just been noticed. Even if there is a problem in the booster not related to this, the master and posibly the rest of the brake system must be dealt with at any cost.
Thanks. Looks like I'm missing both nutsLook at the link below. There should be two adjustable lock nuts on the switch. The switch does not thread into the bracket, the two lock nuts hold it in place and allow adjustment of the switch. Sounds like you may have lost one of the nuts.
https://www.paragoncorvette.com/p-350096-brake-light-switch.aspx
