Dulling door jab clear coat
bobs78
Hot AZ
50th AE vert - 25th SA - 54 Polo White
Has anyone tried Krylon® Dulling Spray to dull their door jab clear coat finish? Maybe this be used to dull the jab during juding. Krylon claims that it "provides a removable dull finish for items to be photographed or videotaped. Reduces shine and simplifies lighting arrangements. Removable finish wipes off easily semi-drying formula leaves no marks."
Could this be the answer for us base/cc guys?
Hampton Ga
1968 silver coupe ,1954 packard
Im confused,why do you want to dull it?
motorman
pa
2008 Crystal Red Tint Coat
go over too www.vetteheads.com ,click on tech and post this question as there are guys over there that do this for a living
bobs78
Hot AZ
paintdaddy, as I understand it for NCRS judging the biggest give-a-way to a non-original clear coated paint job is the high gloss clear coated door jabs. My 78SA was repainted with base/cc but other than that its original. I'm thinking of having it judged so I'd like to dull down the door jabs so its not so obvious its cc'd.
motorman, thanks for the suggestion...I'll check it out.
Vettehead Mikey
Not that far from Ottawa
1973 Coupe
If your car is painted in typical BC/CC style, don't worry about your door jambs. During judging, your paint job will stand out as 'non-lacquer' from 20 feet away.
bobs78
Hot AZ
Thanks for your opinion, Vettehead. But I'll worry about that when the time comes.
