69MyWay
Clock is ticking. I have basically two weekends left to square of the last minute details before Sharkfest.
As many of you know, I have been battling clutch problems. Still not sure until I get the Quartermaster returned for an inspection exactly why/what is causing it to slip.
I love the hydraulic conversion. My pedal effort is smooth, clean, neat, and there are no engine vibrations, rattles coming through the pedal of the standard Z bar design.
However, I am concerned at least with the LUK clutch I just put in the car to get me going that I will have problems again soon. This is why. The hydraulic release bearing uses shims between the trans and bearing to get about 1/4" clearance with the clutch fingers. As the clutch wears, this space goes away causing the release bearing to end up riding on the fingers=slip=angry Vette owner.
The LUK clutch was so close when I installed it that it required zero shims. That means there is nothing to remove later as that disc wears in place, meaning a future trans removal and head scratching session.
So, just kind of thinking out loud here. The car felt great last sunday afternoon for the little bit I could drive with a non-charging alternator around the block. The LUK clutch is smooth, tight, and quiet. However, you can just tip toe the clutch pedal and it releases way at the top.
My thoughts......Yank the trans AGAIN this Saturday morning or at least get it started over the next couple of nights. Remove the hydraulic bearing, swap it with a standard release bearing, install the ball stud and clutch fork, install the ball stud on the engine block, install the Z bar, remove all the Sweet hydraulic stuff from the firewall and pedal/swap with linkages, and set up with a full standard clutch....for now (until the six speed comes back in the picture). I am thinking I would leave the resevoir on the firewall as that will come back in handing with the Richmond as I fully intend to run that as a hydraulic (got to sell something around here first so I can buy the thing).
Or...just let it ride like it is until it actually does wear enough to slip, then look into the six speed.
