S
sothpaw
I went to Woodbridge Dyno tech in Virginia today, a very classy, recommended dyno shop.
With the DynoJet (not a mustang dyno!!) my best pull was my last, after we waited for the car to cool (oil temp was 172):
Max Torque: 336.4 ft-lb@4500rpm (from 3600 rpm to 5000 rpm is at or above 330 ft-lb--very flat)
Max HP: 352 Hp @6200 rpm(from 5900 rpm to 6300 rpm is at or above 348 HP, max 352--very flat).
The previous run was similar, but the car was warmer, probably in the 190's. Max HP: 344. Max tq: 333.
I'm really pleased with these results. The curves show no sign of hesitation or spark knock, so the stock injectors and fuel pressure are adequate (never did the AFPR).
--So, my mods end here. Special thanks to RRubel(that book had great test data on modding the LT1, and it was dead on correct) and Vetlt193 (you discouraged me from the hotcam, that is why I went with this custom comp cam).
