Wajulia
Hi all
Just rebuilt my E4ME, mainly because it was sitting on my car without running for about 10 years.
I started it this weekend and the choke worked fine, but when it opened it would not idle, I slowly adjusted the idle air bleed valve and to my surprise, the engine began to idle as smooth as can be.
My question -- I know that should be adjusted with a dwell meter, How is the meter connected to the carb. Is there a connector that can be purchased to allow the dwell meter to be attached? Do you all make your own, if so where do you get the parts?
