Rocketkid
Check engine light is on,
I changed the coolant sensor with a NAPA sensor, cleared the code (disconnected the battery), the check engine light came back on.
I checked ohm on the the sensor it's reading 250-300 hot 5.80 K cold, I was told that the range should be 1k & 100K.
I bought a sensor from the chevy dealer, it's reading about the same as the NAPA sensor (250-300 hot 5.80 cold).
I checked continuity from the sensor to the ECM, it seems to check out fine.
Any ideas what could be causing this problem?
