R
Randy 71
Vetters, I finally bought one and put it on. I am having some difficulty. this was my first carb replacement I followed the instruction closely. Everything connected just fine. I heard that it was basically a bolt on and go. Not in this case. Here are the problems as I see it.
1. Secondaries are not opening. Here is what I have observed. It appears that the throttle is not traveling far enough to engage the secondaries. Does not appear that the length of the metal rod can be adjusted so that it engages the secondary metal (thing) that pushes open the secondaries. I have noticed that were the secondary linkage/rod
recoil spring is located that it might allow for an adjustment. Is this true? If so, how do I reduce the travel of the throttle to allow the secondaries to kick in?
2. Related to #1, I think. The diaphragm on the choke side does not appear to functioning properly. I believe this is also preventing the secondary butterfly valve from opening which is not allowing the secondaries to open. Any thoughts. I have notices that the vacuum to the diaphragm is content at all RPM's. I thought that as the RPM increased the vacuum decreased and this would cause the diaphragm to open and in turn open the butterfly valve to the secondaries. Does this sound correct? If so, what are your thoughts to correct this.
3. Though I have checked the choke for proper operation. Open when engine is cold then hit the throttle, then it closes. Problem is that is does not keep the idle up to the engine warms up. As soon as I give it throttle it kicks down and does not idle very well, and will die on occasion. Does it sound like I need a choke adjustment? If so, how?
4. What is the proper way to adjust the Fast Idle Solenoid. Mine pops out when the key is turn. Is this normal. I thought it only engaged when the AC or a heavy load was put on the engine.
Sorry for so many question. Believe it or not these type of adjustments are not covered in the instructions provided with the carb. $417.00 for the Carb, I have to say I am disappointed so far. I heard so many good things about it.
Thanks in advance
Randy
Thanks in advance
Randy
