Question: Edelbrock Throttle Cable
Most Edelbrocks are mechanical. If vacuum there will be a vacuum pod with a rod attached to the secondary shaft. Another way to check if you are getting full pull on the carb is to have someone push the gas pedal to the floor then see if you can push the carb further open.
Gary
SAVE the WAVE
