G
grpups
Can someone confirm when the engine if not running that the exhaust heat valve is in the OPEN position? The valve is suppose to CLOSE whenever vacuum is applied. If this is the case, the valve should always remain OPEN if I disconnect the actuator rod and/or the vacuum hose at the actuator. I read an earlier post that someone removed their EFE system and tack welded the valve open. Why would this be necessary? Thanks.
Note: I removed my A.I.R. system and noticed the difference in performance. Hopefully I get more of the same when I eliminate the EFE system.
