Hrtbeat1 said:Both the EGR valve and the solenoid are under the plenum ... should be just infront of the fuel pressure regulator. Are you getting a code 32? I guess it could make a car run rich.
C ya
If you loosen all the runner bolts on the passenger side then remove the plenum bolts the plenum will slide right out. Maybe a whack with a rubber mallet before removing the plenum bolts (be careful its not that thick and Aluminum). Of course you need to remove all the plumbing and disconnect the electrical connectors, don't forget the one on the underside of the plenum, and the vaccuum feeds at the end of the plenum that go to the brake booster. My gaskets were OK and just reused them, although I had a new set, they use a little plastic pin to hold them to the plenum during reassembly.Edmond said:Can I replace the EGR with just taking the plenum off or do I have to take the runners off as well? What about the gaskets? Are they okay to be used again or should I go with new gaskets?
Vettefan87 said:Take the TB bolts off. Remove the linkage. Remove the vacuum line for the brake booster. Then take off the runner bolts to the plenum. Am I missing anything guys...??
