C
ChipHead
Well here I sit, thinking, "I must be the only person in the history of cars with this problem!". The reason I think this is because no one has been able to help me with this so I turn to you...
I have an '80 vette (duh) and I just installed a new radical camshaft, performer intake, performer heads, edelbrock carb, headders and roller tip rockers.
After running the engine and breaking in the cam I desided to take the car for a little spin, nothing crazy but just around the block. When I came back I had broken a rocker arm stud and bent a pushrod. Well I bought a set of 'Magnum' push rods ($100), and put it all back together and the rollor tip on the one that broke was damaged so I bought a set of true roller rockers($175), well now the valve covers won't fit, so I bought a set of Edelbrock Signature series aluminum Valve Covers($75), well now the EGR Valve won't fit. This is where I need your help.
Has anyone EVER had this problem. If so what did you do to fix it? I live in Cali and have to keep this car smogged so I won't just block it off.
Please help?
Adam
Please help?
Adam
