R
Roy
I purchased a crate engine that came with a Holly carb with an electric choke.
Question: Do I wire the electric choke with a (+) wire that is energized when the ignition is turned on, OR
Do I wire the electric choke through a thermostat that then is wired to the electric choke?
My concern is "Does the electric choke when the engine is warmed up if it does not get a signal from a temperature thermostat?" Does the electric choke have it's own internal thermostat that controls the opening and closing of the choke mechanism?
If I only need to connect a wire that is activated by the ignition, which wire is the best to use? Can a splice a wire off the (+) feed wire to the distributor? How about the (+) wire that feeds the blower fan that is always "on" when the ignition is "on"?
Thanks.
roy.truelsen@verizon.net
Thanks.
