K
KenSny
My stock fan is starting to slip so when I do some performance upgrades (cam, heads, carb, etc) this Spring I'd like to install an electric fan and get rid of the clutch fan setup.
My nephew works in a "recycling yard" and says if I tell him what I can use, he'll keep an eye out for the assembly.
My car has a working A/C and a condensor in front of the radiator. Currently has a 17" fan with an 18" shroud. Not much room around the current shroud to expand with a different size shroud.....
Question: Has anyone used a single 16" electric fan from a GM car with any success. I noticed that a lot of people use dual fans. It would seem that a mid-90's Camaro or Firebird would work also. Are you using a pusher and a puller or two side-by-side pullers?
My upgrades will probably take the engine to 330-350 hp so I would like something to keep it cool. I use a 180deg thermostat now.
Also - does anyone run the fan all the time, or are you all running with relays and thermo switches? I don't see how it would hurt anything to run the fan all the time.....
Thanks.
One other thought I had was the current draw. I have a stock alternator (60a, I think). Wondering if I would need to up the amps?
Thanks.
