L
LNS88VETTE
STARTED OUT FINE, DROVE AROUND ALL MORNING, STOPPING AND STARTING; GOT HOME, TWO HOURS LATER CAR TURNED OVER VERY SLOWLY; CHECKED BATTERY HAD 12.3 VDC; CHARGED IT AWHILE STARTED UP BUT IS SEVERLY MISSING; TIMINGS PERFECT, NEW PLUGS & WIRES....NO CODES ARE COMING UP; BUT MY DASH IS GOIN CRAZY TURNING ON AND OFF ALL GUAGES ARE SPERATICALLY JUMPING UP AND DOWN MY AC DISPLAY IS REVOLVING GIBBERISH....ECM? IF SO ANYONE KNOW WHERE I CAN SEND IT TO HAVE IT CHECK OUT AND OR REBUILT???? OH AND WHATS THE EASIEST WAY TO GET TO IT; TIPS WOULD BE GREATLY APPRECIATED
mad:ugh
Well, after many hours the problem was solved, but not quit sure if all or just a portion of the issues were the culprit....when reevaluating my grounds (3-4) on the drivers side of the bell housing next to my 02 sensor i traced them one by one and found just one had broken inside the insulation and butt spliced it...she stared up and ran smooth, went for a test drive and had a severe lack of power, checked timing and was intermittently correct ( 2BTC); pulled my distributer found the a chaffed wire and a tooth missing off the gear.. replaced the distributer and all is running absolutely purfect...... thank you 4 ever ones help and input!!!!!!!!
