Gunner41
I have a problem with my R/L turning light indicator in the instrument cluster panel. The light indicators are both lit and when I turn on the right or left signal they will flash/flicker and the lights that lights up the instrument cluster panel also flashes/flicker.
Now when I lock the car using the FOB my front R/L signal/day light running and rear reverse light Flashes/Flicker. When I unlock the car using the FOB the lights stop flashing. I need to know what is the problem and how can I correct this problem. I really need help with this, thanks for your support.;help
