7
72 Bluz
Went to clean the engine compartment Sunday - battery was low and I jumped her off, let her run for a while, and proceeded. After finishing, Xena started right up - let her idle for 10-15 minutes and then Judy took her for a spin. When she returned, I noticed the headlights were dim. Looked in and the amp gauge read discharge. Goosed her D ) a little and the headlights brightened back to normal and the amp guage began registering a charge again. Let her run a little longer and put her to bed before starting her up 2 more times. Got home last night and there's no charge, the engine would turn over 2 or 3 times and stop. Covered carb, distributer and alternator while cleaning. My first thought was maybe the alt belt was slipping because it was wet, but then there was little charge before I started and had to jump her. Will get the battery checked tonight, but wonder if it could be something else. The battery is pretty new and as checked out strong recently. Thanks for any input.
