L
LarryK 87
Ok, Lets try this one on here...
During normal ( non-liquid sunshine days), Engine generally always runs fine, occasionaly right after startup depressing the brake pedal will cause the engine to run a tad rough.
Friday driving home, It was raining, turned on the wipers, and came up to a stop light, engine running REAL rough, release brake... engine settles back to normal, Brake on... bad Idle. Wipers Off.... Depress brake, engine idles normal.
Voltage was around 12.5 or so with wipers and brake on ( possibly dropping, but could not tell). Relase brakes Voltage back up to near 13v or so.
It sounds like a moderate load seems to be pulling the ignition down. I suspect there maybe bad or marginal grounds, and was going to check them this weekend, but cannot seem to figure out how to get the battery out of the car!!! ( sounds simple enough eh!!!) without disassembling the Cruise control diaphram, and support piller that runs over the top of the Battery.
So possibilities are... ????
1. Bad Grounds G101, and 401 ( to start)
2. Altenator simply not putting out suffecient current?
