/wamp ... Can I run it to coil in the mean time?
In mean time: Yes, run tach's trigger wire to coil's negative (-) post. Leave plenty of wire so you can run to msd box if get one.
For later: The MSD 6 boxes have a wire that is specific to trigger a tach ... no problem ... just connect that trigger wire from tach that you left plenty long.
My question: Do you presently have a points-type distributor ... or has it been retrofitted w/ a chevy HEI?
MSD Blaster HEI Coil (pn:31769) is there any better or is this a match? To many choices.
Are you sure of this pn ? ... doesn't look like MSD pn for MSD coil.
MSD 8203 is Blaster oil-filled canister style--must mount vertical
MSD 8222 is Blaster High-Vibration epoxy-filled canister style--mount any way
(I have an xtra, new in pack 8222 I don't need ... $30 vs $40)
MSD 8225 fits into top of GM HEI distributor cap--mount in cap
MSD 8252 is HVC e-core--mount any way
I’m gonna run MSD HVC pro box 6600 & cap conversion pn 8401 & pro HVC coil pn 8250 w/ gutted GM HEI & Accel 300+ 8.8 wires with 75 tach in my 71.
I'm sorta 90% there on my setup ... go ahead & ask q's. I also have a few other MSD pieces for sale including an xtra, good used 6 box (nascar 6TN pn 6401) & an xtra, new conversion to run outside coil w/ HEI (pn 8401). Have an xtra set of new Accel 300+ ferrospiro 8.8mm wires too.
JACK:gap
