BigTom1957
I want to get rid of my computer or at least not use it for the carb and ignition, this is a 1981, I have changed pistons to raise compression installed a comp cam, and am thinking I want use a holly spread bore. The Qustion is how do I deal with the lock up torque converter if I do not use the computer? I will also be changing the distributer. The compression should be about 9.5 to 1. TIA Tom
