Kenny
On my 93 located under the ASR unit is a solenoid/valve? that is in the line that runs from from the AIR pump to the engine. On that solenoid/valve there is a small hard line maybe a vacuum line. It goes under the alternator. That's it. It ends there nothing connected to it.
Is that right? Looks like a vacuum line should be connected to it. Or is it a vent? Can't see anything under there. Haven't found a vacuum diagram in the FSM yet. Doesn't seem to be a problem car runs fine
