topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
In a L-98 that had dead multecs my friend took his 90 to a idiot and he installed 19lb per hr ford injectors " the numbers come back as Bosche replacement number for a 302 or 4.6 V-8. Ever since this car has had a cooling issue that originated back when the multecs were dying. Now the car has intermitent hesitation when under a load or when in higher gears and engine is lugging.
what could the ecm potentially do or see in these conditions. If in fact it is lean could this hesitation be the ecm seeing detonation and retarding timing and if it was continuosly doing this could this explain the high coolant temps?
Can the ecm correct fuel issues to make up for the 19lb injectors and or is 19lb injectors to far out of range for the ecm to make corrections and it is unable to deliver enough fuel?
What do aluminum heads and 10.25:1 compression suffer from lean conditions?
aside from this car having a very minor coolant leak and it doesnt leak all the time it is totally stock and in great mechanical condition. So I am wondering if he is either dealing with a massive lean condition or cats plugging.
He has new motor sport 24lb per hr injectors "aka ford blue tops" Of which I told him to run at 40psi since ford injectors are rated 24lbs per hr at 39psi and when run at GM's 43.5 psi they deliver around 27lbs per hr.
whats your opinion on this car?
