GranburyZ06
New member
I recently purchased a black 04z with 5500 miled on it. The car is in near perfect condition inside and out, but recently have had some problems. Now she normally will not start unless I quickly flick the accelerator pedal while turning key. If not it just keeps turning but will not fire up. This problem is intermitten but happens more ofter than not. Also check engine light came on with the
1) P0174(Fuel Trim System Lean Bank) and
2) U1064H code (Loss of Communications with BCM)
The car seems to sound and run fine once I get it started
Now I just have her sitting in the garage. If anyone has any ideas they would greatly be appreciated.
Thanx
Thanx
