engine coolant
cuvette
montreal
2000 yellow convertible
Hello i will like to no i will replace my engine coolant i much dex-cool i have to put or buy for my car thanks and regard
Mick
Look in your owner's manual for the capacity of the cooling system and divide that number in half then buy that much Dexcool. That gives you a 50/50 mix.
flush and drain the system per the FSM then pour in the Dexcool and top off the system per the FSM using tap water or, if you want best results, distilled water.
Thanks a lot for the tip Hib
regard
Hib, good tip about the distilled water! Makes a big difference.
You can find distilled water at your grocery store and usually costs about a buck a gallon.
SAVE THE :w
SAVE THE :w
The grocery store is where I usually get it but, don't mistakenly buy "deionized" water. Make sure the label says "distilled".
