Engine Heat From Dash/AC
bobfil
roch.ny
1972 convertible
Explain how you would fix the valve that is senting hot water to heater core, since I'm having same problem, thanks Bob.
I also saw another article about sealing the air intake duct that is under the right side kick plate. Basically the sealent will crack with time and use(just like the body panels), and will draw air in from the engine compartment instead of from the vents by the wipers. I also wrapped the fan box in the engine compartment to keep the heat from the exhaust manifold away from it. You can get the wrap at sumit racing, I bought mine at a local hotrod shop.
